Old 12-03-05, 08:10 AM
Bob Cook Bob Cook is offline
cowl motors
Guy
1) Has your mechanic checked the resistance of the motor?
2) Suggest you soak it in CRC contact cleaner and try applying 24v momentarily to see if it may work.
3) if you are technical then check brushes.
oil from front engine can cause problems and create enough dirt etc. to stop it's operation.
keep linkages well lubricated and always adjust limit switches with full voltage on system to avoid overuns when set by low voltage (suggest adding battery charger to aircraft while adjusting.
I find spraying CRC cleaner after every oil change makes a big difference in performance and reliability.
if all above fails then "open the wallet"
for what it's worth..........
Bob
