Unread 11-15-05, 06:27 PM
FRED-E's Avatar
FRED-E FRED-E is offline
A&P/IA
Horn
Did you take out the throttle micro switches at dual warning unit??
.... No they were disconnected at the engines
As you operate the squat switch can you hear a relay operate in the center console?
.... Yes I can hear the relay (does this relay do the same thing as the solenoid for the up/down lever on my 337B)
If this relay does not energise when the squat switch is operated the horn will sound. So it does sound like this relay is intermittant, it is located in the center console above the power pack port side.
I will check that relay this week.
Thanks again
Fred N358
