Old 10-04-05, 07:04 AM
Travis,
Go to the Home page of this web site, on the left side go to Technical Data.
Near the bottom of the Technical Data page you will find a link called "Electrical System Schematic (PCX format). It is a diagram I made up using the wiring diagram for the B model which also uses the 38 amp Ford system. It may help you out... It even may be easier to read than the Cessna one.
If it's not identical to yours it should be very similar.
Good Luck!
