Old 09-26-05, 05:40 PM
If you reduce oil to 6 qts, you shouldn't need an oil separator. If you've got considerable oil after reducing to 6 qts and degreasing thoroughly, then it's not likely to be out of the crankcase vent. There ought to be a leak somewhere. As big al 08 says, degrease, run it, check, repeat, etc.
