Unread 06-01-05, 02:30 PM
skyking, did or i think i did your instruction as per and the gear doors would not pump up (do i need to select the up position first?) nut they pumped down, they returned to the up position with the cb and master on. also slowed down to 80 when i was cycling the gear the second time when they extended. i have had this happen before, except for the pummp handel becoming very still with only 2 or 3 pumps. thanks
