Unread 07-04-02, 10:08 AM
Bad Idea
Good morning, Richard.
GMAS talked about this at TC. When the nose wheel retracts, there is a very small space between the bottom of the engine and the wheel. Putting a quick drain on the front engine will practically guarantee that the drain will hit the tire...... With vibration, you'll end up with a hole in the sidewall, a bad thing.
