Old 04-04-05, 10:49 PM
warped brake disks
has anyone had to have the wheel disk machined (as in a car) to correct warping and concurve wear in the disk. brake pads do not fit flush and only part of the pads touch the rotor or diak. i think i am only getting about 50% effective braking.
Old 04-10-05, 07:35 AM
sunnysky sunnysky is offline
Buy some new discs. They aren't very expensive.
Sunnysky.
Old 04-10-05, 02:00 PM
Machining disc
Yes, not a problem as long as the finshed thickness is within specification limits. It is done all the time.
Jerry
N34EC
Old 04-10-05, 04:44 PM
found some in dallas, old one too far out of tolerance
Old 04-10-05, 06:59 PM
Check with Don Nieser. He has some and at reasonable prices.
Old 04-29-05, 06:47 PM
Big Al requested that I post this for him. I expect he will get on later and tell us what we are looking at...
Old 04-29-05, 08:18 PM
vip parking, fast taxi for perferred curb side. actually stopped 200" past end of runway, no friggen brakes. by luck was able to steer maybe 7-10 degrees to miss the sign in background, over rocks and the stump you see stopped by lodging undereath the belly. ripper of a bottom com antenna, bent the front exhaust and the left wing tip was cracked by a tree not the the photo. i'm not in the photo just my groupies showing up for the 15mun of fame. have put the new rotors on and all is well. approch was with a 15mph cross wind which was swerilling and ended up as a tail wind on touchdown. not enough time for a go around 1600"with a 40" downhill slope (became complacient knowing i have landed many times with crappy brakes ).
Old 04-29-05, 09:37 PM
SkyKing SkyKing is offline
Yah, but Big Al, you forgot to tell us where this all happened!!! And was that 200 inches, or 200 feet? Inches = " and Feet = ' (just to keep your story straight!)
SkyKing
Old 04-29-05, 11:25 PM
sorry Homer
200 feet past the end of the strip. the photo is not clear but there is a road at the end of the runway & you'll see and square dark sign at the end of the pista.
private strip at my house (mmdei)
Old 05-03-05, 01:32 PM
Hi-oh-silver....
Say, Big Al.... ergh, I mean Hombre.... I don't have a Mexican dictionary... and excepting for the word 'Peso' I'm not exactly sure what a 'Pista' might be... but of course, I'm sure you were 'Pista-Off' at your low-level log rolling event. Was the big front prop spinning, or had you shut it down? It sure would be great to see some additional pix of the scene of the crime.
SkyKing
Old 05-03-05, 05:53 PM
pista = runway, and you're correct i was pissed___. no, shut down both mills and gas/master off when i relized i traveld too far for a go around. the skymaster are agile in the air; however on the ground w/o brakes is like guiding a whale around the dance floor, basiclly the pig goes where it wants.
Old 05-03-05, 11:23 PM
Keven
Okay
So that's entertainment!
For a fella who has likewise resigned himself to one landing . . . good, bad, or indifferert, with front prop feathered on 1/2 mile final . . . gear down, and clam shell doors stuck open . . . that's entertainment. But -- I bet you didn't have firetruck waiting on you.
Good job with what you had to work with.
Keven
Free porn streaming
Old 05-04-05, 02:00 AM
Keep CLAM!
Keven,
You need to shed those clam shells doors... RT Aerospace has what you need. If you ever have one quit on you on takeoff and the clams are cycling... or worse yet... stuck in the open position, you won't need to worry about feathering. The ground cometh quickly.
SkyKing
