Old 01-29-05, 09:33 PM
337G 337G is offline
337G is an unknown quantity at this point
cold weather ops
Thanks every one for your 2 cents. I was mostly looking for a cut off temperature that was being used but the range seems to be any where between -20 to -30c. As you all know the POH is very vauge. I will also have to see if I can get a copy of the continental manuel someplace.
SkyKing I have used in the past on other aircraft the automotive type heaters. They are small and fit nicely in the cowl flap opening or in the front cowl inlet. Just be sure to not block the the air inlet with the engine tent.
Dave what are you doing in the UK now? Was in London just over a year ago myself peparing for my time in Mongolia and Africa with some cross culture training in Ashford.
cheers
