Thread Tools Rating: Thread Rating: 2 votes, 2.00 average. Display Modes
Old 11-30-04, 11:15 AM
Kevin B Kevin B is offline
Question Loss of airspeed indicator
Tuesday night at 16,000ft in 0c to -5c temp my airspeed indicator went to zero there was a trace of ice and it was snowing. the pito heat was on and I could see no ice on the wing strut where the pito is located. Decended to 14000 and the air speed came back. I know the pito heat works at least on the ground when I checked it. Any thoughts?
Kevin B
Old 11-30-04, 03:06 PM
Hi Kevin
Sounds like the static system on one side got some ice in it.
You need to get the pitot and static system pipes blown thru with dry air.
Pete
Old 12-01-04, 04:37 AM
As you're trying to piece this puzzle together, let me add some things you may not have considered...
Virtually all of our training in pitot/static failure modes is in unpressurized aircraft. Even the recurrent training at Flight Safety & RTC does not cover the variables that a pressurized system introduces.
How does pressurization complicate this? If you have a static leak inside the pressurized vessel, some very strange things happen.
For instance, upon takeoff, adding power will lower the indicated airspeed (i.e. peg it at zero). It also shows a descent on the VSI and altimeter. Pulling back the power has the opposite affect - suddenly the airspeed comes alive and the apparent descent ceases.
At altitude, if the static reference opens to the cabin air, it would suddenly increase by the dPSI (i.e. 3.35") which would cause the airspeed to peg at 0. You would also notice both the VSI and altimeter showing a rapid descent.
While there are lots of pitot static connections inside the pressurized vessel, I believe the most likely source of a leak would be the alternate static switch/valve.
In your case the problem was intermittent - and if it was unaccompanied by strange VSI and altimeter behavior, then I would guess that it was a blocked pitot tube. In any case, the first thing to do in this situation would be to try the alternate air to see what (if any) effect it has on the problem.
Old 12-01-04, 07:00 AM
Thanks Kevin.
There was no rapid movement of the VSI and I varified the cabin pressure so I think it was a blocked pitot tube?????
Old 12-02-04, 02:35 AM
You're probably right, but a little more research is probably required.
On your model ('76 P337), the static ports are in the left strut. There are two small holes facing forward. I believe the lower is the drain (I could be wrong). The question is if the pitot hole is blocked, and the drain tube open, will it read 0 on the airspeed? Normally I'd assume this to be true, but since the drain hole faces forward, I don't know what to expect in this situation.
