Unread 05-20-04, 07:56 PM
Plexiglass Protector Removal
Help! I bought some 1966 vintage windows to replace some badly scratched ones on the Skymaster. The protective cover doesn't seem to want to come off. I called the manufacturer and they said to soak it in kerosine for 30 minutes and try to remove it. They said it might not work... It didn't. I have soaked it for over 30 hours. It still doesn't.
Anyone have any other ideas that would not hurt the plexiglass?
Unread 05-22-04, 10:19 PM
docbob docbob is offline
docbob is an unknown quantity at this point
Aircraft Spruce has a product called "Un-Mask". I have used it with some success but I really doubt that you will find anything that will help with something as old as you have.
Good luck,
Unread 05-23-04, 09:11 PM
DocBob...
Thanks for your response. I Think you are right. As old as the bond is, I don't think we'll ever get it separated.
Unread 05-24-04, 03:26 PM
Dale Campbell's Avatar
Adhesive Remover
Try Fin-L-Wash. Made by Martin Senour Paints. It is a product you can pick up at automotive refinishers. It will remove any adhesive ever old stuff. You may have to soak a while if adhesive is old and brittle. It will not damage plexiglass, plastic or paint. I use it all the time to remove stickers, even baked on stickers from computers.
