Dale, kevin is correct. But to tell you the truth when I first started the test, I turned the mags to off and sure enouhg the engine stoped. Then I realized that what I needed to turn off was the master switch, and it worked like it should. I did the test on bouth engines on (Bouth, Left & Right) it works like it should.
Francisco Last edited by Francisco : 10-04-03 at 10:02 PM. |
