Unread 09-09-03, 03:56 PM
w1bw w1bw is offline
w1bw is an unknown quantity at this point
Differences: pre-G vs G/H models
I'll piggyback on this thread about differences between various skymasters. I'm just starting the process of considering a normally aspirated 337.
The big dividing line is clearly the F to G model transition. I've read the article on this site which also appeared in one of the Cessna group magazines extolling the virtues of the late-pre-G models. From this and other info, i see the following differences (older vs newer):
Gear: hydraulic (optional dual) vs electro-hydraulic
Fuel: main/aux tanks (124) vs integrated (148)
Seats: regular middle row vs bench
Weight: empty weight 230 less on F vs G
Door: normal vs swing-down
Cabin: F 4" wider than G
Windows: larger side windows in F vs G
Noise: F more noisy than G
Speed: F 4kt slower than G
Is this all accurate? I think there were other seat changes during the G/H model run, but not sure what changed when.
I'm particularly interested in hearing from those of you who have flown models on both sides of this fence. I generally like later models of most things, but cabin comfort is important.
