Old 07-20-03, 03:54 PM
SkyKing SkyKing is offline
You're JOKING, right?
Why would you EVER put automotive fuel in a Skymaster? Does not the manufacturer of both the engine and the airplane give adequate notice in the POH under "LIMITATIONS", or has the trend to not read reached epedimic proportions?
Both the POH and TCM Operator's Manual clearly articulate the "minimum grade aviation fuel for this engine is 100LL or 100. In case the grade required is not available, use a HIGHER rating. NEVER USE A LOWER RATED FUEL."
Gee, why not just put turbine fuel in it....DUH!
SkyKing
