Old 05-23-02, 06:22 PM
Diode for Alernator condition board
There are several diodes on the Alternator condition board. The manual and the diodes themselves say 3AF4. I can't find these on the radio shack site. Wondered if there was a substitution number or what the value for these diodes were. This is on a '79 T337. Thanks.
Ed
Maine marijuana dispensary
Old 05-23-02, 10:53 PM
Bob Cook Bob Cook is offline
diodes /3af4
Ed
The diodes are 3AF4 (which means 3 amp 400 peak inverse voltage rating).
Radio shack is pretty much out of handling components and I don't believe they are supplying these anymore.
You can get them at www.fairradio.com new and surplus 4.--/2.50. They are available at most jobbers and from Phillips semiconductor. Just tell them you want 3AF4 or equivilant. Larger current up to 5 amps or higher PIV won't hurt as long as they are BOTH THE SAME.
Let me know if you still can't get your hands on some and I will help out.
Don't forget to change the CAPS at the same time. They should be 450 - 500 MF at 100 volts (electrolytics). Careful how you put them in because these are polarized and the end with the band or indent is the negative side. Observe the old ones as you remove them. Same for the diodes.
Bob
Old 05-23-02, 10:59 PM
Thats exactly what I wanted to know. Thanks Bob.
Ed
TX16W
