Unread 11-11-24, 11:06 PM
Touch up paint to protect against corrosion
Hello everyone,
I was looking at having my aircraft painted in the next year or so but have decided to wait until I finish other projects. I do have some paint missing on the alerion (not all of it, but just a large patch on the trailing edge. I want to protect the surface from the elements. Can I sand and spray paint over that edge without dealing with issues such as balancing. It is a small patch about 3 x 5 inches. How much would be too much before you would have to perform a rebalance on the alerion.
That would go the same for flaps. The have the place where they run up against the wing root. Normally there would be nylon inserts for some protection.
Karl
Unread 11-16-24, 01:50 PM
bigcheese
A good commercial paint shop...
Commercial paint suppliers (such as PPG etc), such as service auto paint shops, should have a $20k color scanner they can bring to the airplane to determine paint codes, ALMOST perfectly.
For parts that can come off, you can bring to a good local auto paint shop.
You can also buy nice inexpensive airbrushes with compressors etc.
Balancing controls another question.
I would think the design counterweights should keep everything quite stable, unless you slop it on. The following demonstrates
https://youtu.be/xJTtp_8_z6c
Unread 11-17-24, 01:54 PM
Awesome video,
