Unread 12-23-23, 09:29 PM
I recently bleed mine very troublesome, eventually used my pressure pot from the calipers, installed a fitting where the vent plug is on the master cylinder ran a hose from it to a can, quite a bit of fluid run through it until the air was removed, PITA.
Dan
