Unread 07-26-23, 05:12 PM
Frank Benvin's Avatar
FYI
Ordered a alternator seal using the part # from the Continental IO360 Parts Manual thru Aircraft Spruce Part # 352068
This has happened twice now
Received a SKF 9613
Alternator had a SKF 8648 in it
Just looked at aircraft spruce it it shows this part # is for a Generator Attaching Parts for Continental C85, C90 & 0-200
If you are ordering parts you might want to double check what you need and what you will get
1967 337B
