Unread 01-11-03, 09:11 AM
turbo temps
curious if my tit temps are close. 73 p cruises 1440 degrees climb below 1500. book temp tit limit 1650 degrees. engines running well within ranges est 60-65 % power. latley rear engine running higher tit. last annual i scorched three cylinders/valves operating lop. my gem 603 tit number is easier to read than the bar graph. probably accurate too? what tit ranges are you running cruise /climb. j
