Old 07-04-23, 02:06 PM
CenterlineT CenterlineT is offline
CenterlineT is on a distinguished road
eyeball vents
Hello,
Has anyone installed eyeball air vents in your 337s? If so, which one?
Thanks for your replies in advance.
Allen
Old 07-05-23, 11:49 PM
Hi Allen, I have installed “eyeball” gasper valves. I’m in the process of finishing my panel restoration now. The gasper valves I chose are from Aveo Engineering and are the AVE-BVBLK-001, AVE-BVBP-150 model. You’ll need a Y-adapter to install two of them.
https://1drv.ms/i/s!Apiok8NRRsL6nZlEw1i37lebxXS6FQ
Rick
N337K-FT337GP
KLOU
Old 07-06-23, 11:06 AM
Cglencross's Avatar
Cglencross Cglencross is offline
Cglencross is on a distinguished road
Stc?
Stupid question, do you need any stc/certs before doing this?
Chris
Old 07-09-23, 06:57 PM
Gasper valve
But speaking philosophically, when is 'need' merely a way to more forcefully express 'want?'
Old 07-09-23, 06:59 PM
Gasper valve
The outside inlets port from the wing leading edge.
What are you 'porting' to the dash valves? Heat / air from below?
Old 07-09-23, 11:53 PM
Hi David,
My 1976 P model has a blower motor above the pilot’s left ankle. The output originally went to louvered vents at the top of the radio stack … those vents are no longer available.
Rick
N337K-FT337GP
KLOU
