Old 06-23-23, 07:33 PM
Bryan,
We do my NA IO-360s each annual with a very cool test set my avionics shop built. If you can make it to central OK, happy to help get yours all tuned up. It can be done by any A&P who can read the procedure. Turbos are a little trickier.
The procedure is straightforward and described in the old TCM SID 97-3, and now published in the TCM M-0 manual available on the tcm site. Usually takes a couple hours and several runs to get both engines dialed in and purring.
-LJ
