Old 02-17-23, 08:29 PM
Joes Joes is offline
Turbo pump is different than normally asperated
the designation of t337f would indicate a turbo engine, if so the turbo pump uses the upper deck pressure to determine the amount of fuel to the injectors. N/A is gear driven. Two different pumps. If you find an older pump during the rebuild they will bring it up the the latest revision, but check with them before. QAA has done two for me in last 12 mo.
