Old 11-15-22, 07:50 PM
YankeeClipper's Avatar
McCauley governor model for '69 with a c6b?
The Woodward on the front just sheared itself to sprinkles so I'm trying to figure out where to go next. When I looked at the McCauley application guide (as a novice) I saw several governor numbers listed and didn't know where to go with that info.
Also wondering if it's worth it to find a used core for sale, and if it needs to be the same model, or if any Macaulay constant speed (or at least for any year of 337) would suffice as a core.
Thanks.
Old 11-16-22, 09:46 AM
Frank Benvin's Avatar
From AC6C
VI. Model 337D (cont’d)
Propeller and 1. McCauley constant speed full-feathering propeller installation
Propeller Limits (a) (Front) McCauley D2AF34C59/76C
Diameter: not over 76.0 in., not under 74.5 in.
No further reduction permitted
Pitch settings at 30 in. sta.:
low 11.7°, feathered 79.0°
(b) (Rear) McCauley D2AF34C61/L76C
low 10.8°, feathered 79.0°
(c) (Front) McCauley D2AF34C301/76CTA-0
Diameter: not over 76.0 in., not under 75.0 in.
(d) (Rear) McCauley D2AF34C302/L76CTA-0
(e) (Front) McCauley D2AF34C306/78CAA-0
Diameter: not over 78.0 in., not under 76.5 in.
low 11.0°, feathered 82.0°
(f) (Rear) McCauley D2AF34C307/L78CBA-2
Pitch settings at 30 in. station:
low 11.0°, feathered 80.0°
(g) (Front) Woodward hydraulic governor 210443
(h) (Rear) Woodward hydraulic governor 210443
(i) (Front) McCauley hydraulic governor CF310D1/T1 or CF310D2/T1
(j) (Rear) McCauley hydraulic governor CF310D1/T1 or CF310D2/T1
(k) (Front) Cessna spinner 1557303 (includes support and bulkhead assembly)
(l) (Rear) Cessna spinner 1457306 (includes support and bulkhead assembly
Full version here
https://www.facebook.com/groups/2872...55160101479560
1967 337B
Old 11-16-22, 01:26 PM
Thanks Frank.
So my IA ordered a brand new one today from McCauley (or whatever their approved distributor is) for $4300.
So where is everyone getting their replacement, McCauley governors from these days? I see QAA has them for 1350 + 1k core, but my IA was nervous about using an overhauled part.
Old 11-16-22, 01:28 PM
I have 2 DCF310 D7-C/T1 overhauled in April
Old 11-16-22, 02:37 PM
QAA is fine. And I would look for a new IA. He just cost you an extra 2K
Old 11-17-22, 08:56 AM
cfc1234 cfc1234 is offline
cfc1234 is on a distinguished road
Yes, ditto what Kim said about the extra $2K!
Old 11-17-22, 06:49 PM
Kim is a Skymaster guru. We are fortunate to have him in our community.
Old 11-18-22, 04:53 PM
Thanks all for the replies. Interesting thing, when I called Quality Aircraft Accessories they were completely out of stock on anything. They told me to give Aircraft Accessories of Oklahoma a ring which I did. They said they could put together either a Woodward or a Mccauley. I thought this was interesting because all of the indications from all the shop talkers in my world were that Woodwards are no good and you can't rebuild them anyway because there are no more parts. Well this guy says he thinks they're a better governor and he doesn't know understand why people think they can't be rebuilt.
Well in any case, does anybody have any experience with aircraft accessories of oklahoma?
Old 11-19-22, 01:55 PM
Don't use overhauled parts? That's just crazy. What about engines? If everyone had to buy new engines and appliances, general aviation would collapse.
I've heard over the decades that Woodward governors are better, and that's from governor overhaul people. To what degree they are better was not stated, however, so I wouldn't spend a bunch of money to switch from McCauley to Woodward. On the the other hand, if I had a Woodward that needed to be overhauled, I wouldn't switch as long as parts were available for it.
I've had very good luck with Aircraft Accessories, so I don't hesitate to recommend them.
Old 11-21-22, 09:52 AM
Much appreciated.
Old 11-23-22, 02:43 PM
I have many accessories overhauled by Aircraft Accessories of Oklahoma. Good people.
Dan
N67S
Old 11-23-22, 08:19 PM
This is confidence inspiring. Thanks.
For posterity:
  • new gov from McCauley: 4300
  • rebuilt McCauley from QAA or AAO: 2300, 1k core.
  • rebuilt Woodward 210443 from AAO: 1800, 300 core
There is also a newer Woodward that supercedes 210443 for a little bit more. AAO and a few other sources opined that Woodwards are a little better than the Mccauley units, but didn't elaborate on how.
I went with the 210443.
Old 11-24-22, 07:30 PM
5 of our Skymasters had McCauleys 1 had Woodward on it. We had to overhaul the McCauleys every 5 years. Woodward were overhauled at engine TBO.
