Unread 06-13-22, 02:10 PM
rmorris rmorris is offline
Front prop T337C
Looking for front prop options.
1968 T337C s/n 337-0775 with tsio360AB engines
Looking for overhauled or serviceable front prop.
D2AF34C91
D2AF34C304
P3044336-11
Please email price/availability
Could also be interested in the hub or blades/ components of you don't have a full prop
Please email me at networkgunslinger@gmail.com if you have one, or can share any leads on one. Thanks.
Unread 06-24-22, 09:36 AM
C91 or c304
Have had several folks reach out, but they had front props with different hub numbers than I need
T337C can use C91 or C304
Please send any options with either of those front props please
Unread 06-29-22, 09:49 PM
Prop options
Did some more research, and the aspirated and T models use diff hubs (T model nose cowling is a little longer).
Anyway, I can use a front prop from a T337B,T337C,T337D,or T337F.
The two options are:
D2AF34C91 prop
OR
D2AF34C304 prop
I'm looking for a serviceable prop, or the components to have a prop built up.
C91 hub
C304 hub
76C-0 blades
76CTA-0 blades
Lmk if you have leads on any of the above at networkgunslinger@gmail.com
