Old 12-16-02, 08:40 PM
SKYMASTER44 SKYMASTER44 is offline
SKYMASTER44 is on a distinguished road
Brake line braket keep coming unglued
1- Brake line support brackets keep coming unglued. What do you guys use? You know the brackets that attach the brake lines along the main landing gear leg.
2- There is a Skymaster for sale or parts on "Barnstromers"
Tony P.
P.S. Thanks Kevin
Old 12-16-02, 09:52 PM
You're welcome.
As to brake brackets, I use 300 knot tie wraps.
Old 12-19-02, 04:53 PM
Tony Giantonio Tony Giantonio is offline
Tony Giantonio is an unknown quantity at this point
Tiewraps are fine
You can use tiewraps to secure the line to the gear leg and it should be fine.
P.S. you can use the color you prefer.
Tony G.
Old 12-20-02, 09:28 AM
Guy Paris's Avatar
Cool Fuzzz....
A while back, I don't think the Fuzz liked the tywrap on a guys brake line seen on a ramp check.... Guy, old72driver....
Ce$$na has some hi-tech adhesive listed in the parts manual for metal to metal. will check and let you know what it is....
The adhesive is, 3 M 2216 B/A.... for metal to metal....
Old 12-21-02, 02:18 PM
Bob Cook Bob Cook is offline
tie raps
The 300 knot rating. is this ground speed, airspeed, indicated or true.
2) is there any temperature compensation ?
Bob
Old 12-21-02, 05:46 PM
300 IAS. If you look very closely at the inside of the tie wrap, you can see the rating, right next to the PMA certification. You want a Class F tiewrap at least. In Europe, the equivalent code is a Q13-6B or 6C.
