Old 03-01-22, 06:22 PM
GAdams GAdams is offline
I had some loose nuts in the system and yes it does induce air. The handle is all about pressure. Put a wrench on every nut you can find. Top off frequently. Bleed the system again and again. Put the plane on the ramp and run the front engine. Put the handle down. Wait for it to retract. If it doesn't purge then fill, purge again. Repeat. Once you get the handle to return from the down position. Go fly it. Land. Do it again. Repeat as necessary. Many Many Many times.
