Old 02-28-22, 12:39 AM
Granted, poorly operating micro switches can cause indicator light issues. You are a B model with engine driven hydraulic pump. you mentioned the gear handle not returning to the neutral position on its own and you manually moved it to center. Worrisome for a low pressure situation. The causes are numerous. So many times , stung by the basics. Check your fluid level first.
