  #24
Old 11-30-21, 12:01 AM
Ammeter should be hooked in “series”. one probe of the meter hooked to one end of wire and other probe hooked to the other end. Just think of it like cutting the wire and putting the meter in the line, like two leads of a light socket. If you’re able to select, start high on the amperage and work down. I don’t buy very expensive meters and most of those have a 10 amp capacity. It’ll say on the meter. They usually use a fuse and if apply too much current they’ll blow the fuse and end reading zero. If zero reading, check fuse in meter in case it’s blown. You should get some kind of reading. If not back to testing every connection and solder joint
