  #34
Old 05-12-21, 11:09 AM
hayesjaj hayesjaj is offline
Originally Posted by Trippster View Post
I have a 1975 337G with the long range tanks. I'm putting in the EI CGR-30's and I have the total fuel, but does anyone know how many gallons are in each tank on this model? I know the Aux feeds the Mains directly, but I'm told we have 4 fuel sensors, so I need to know how many gallons are in the Aux side and how many in the main.
Tripp
The senders for yours are essentially wired in parallel (via the conditioner box) because the tanks are plumbed together. The multiple sensors are used to determine fuel level when the wing isn’t level and the fuel moves toward one side or the other. You shouldn’t need the capacity of the aux at all. Give EI a call and they will walk you through it but only specify two tanks total for your order.
