Unread 03-17-21, 11:14 AM
OhioSkymaster OhioSkymaster is offline
OhioSkymaster is on a distinguished road
So, did servicing the gear actuator/transmission seals fix the leak? I'm having the same issue of hydraulic fluid leaking from the belly. It's red, so no question of fluid type. After the last flight it leaked a puddle of fluid about 5 inches in diameter in just a few minutes after parking and shutting down, but after removing the interior and deck plates could not find any source of the leak. We're thinking of running the front engine and placing the gear lever in the Down position to pressurize the system and watch for leaks, before jacking and running the system with a mule.
