Just to be clear, my new copilot's panel is a clean sheet re-do, not an overlaid cover. Another thing to be sure of is the allowability of a panel material other than the original material. My original panel was made from a .050 sheet of 2024 T3, so that's what I went back with. My IA at one point made a comment the panel was "structural" which led me to believe that there might be specific requirements for the composition for the panel's material. You should check that out if you're thinking of changing material for your new panel's construction. Here's a picture of the old panel prior to removal: Old panel, installed This is the picture of the old panel: Old panel, removed This is what was behind my old panel, after its removal: Note the brace I was talking about directly above the "FWD PASS AUX AIR" switch. Note as well, where my IA located the forward engine's EDC and sensors against the sidewall. Behind old panel I don't have the CNC file. I worked with a great guy locally who has all the equipment, and expertise, to do the layout, testing and cutting. If the frame of your copilot's panel is the same as mine (or at least close to mine), there might not be too much adjustment for him to layout and cut yours also. There, of course, would be some shiping back and forth until you got it the way you want it. He also, made all new placards and labels for the interior and made a new "Red Ball" for the handle of the emergency gear pump shaft, as mine appeared to have been broken into several pieces and glued back together several times. All of it looks great! We are working on new labels for the circuit breaker panel now. I'll put a photo below of this work in progress, but you'll be able to see the direction we're headed. His pricing has been very reasonable. I can get you in touch with him if you like, PM me and we can set a time to chat about his work, his contact info and all the options for you to consider in configuring your systems. Work in progress on circuit breaker panel Rick
N337K-FT337GP KLOU |
