Old 11-11-20, 02:15 PM
Thanks for doing this, I love to see a new resource for our Skymasters! That said, will this be legal to install on a Part 135 operated 337?
Old 11-17-20, 09:52 AM
When I get the PMA approval it will be. I should be sending the data package to FAA engineering this week, then it’s wait time and back and forth with them.
I am having 100 units made and I do expect my first five evaluation units in about 14 days. The balance of 95 units will follow.
Pricing will be in the 250-300 dollar range. Those that want to do the owner produced part scenario can get them rather quickly.
Dan
Old 11-18-20, 04:35 PM
Dan,
I am definitely interested ASAP. Please let me know when you have them available and what you need from me.
Tripp
Old 11-18-20, 10:39 PM
“2!”
I’m up for the owner-produced route.
Old 11-21-20, 03:54 PM
I'm in for either.
Old 11-23-20, 07:23 PM
First 5 units scheduled for delivery Dec 18. Units will be universal for P models and unpressurized models. The two .070 holes for the pitot head are in different positions between the pressurized and unpressurized models.
Dan
Old 11-24-20, 10:10 AM
Dan
Confusing statement - "Units will be universal for P models and unpressurized models"
but then you say - "The two .070 holes for the pitot head are in different positions between the pressurized and unpressurized models."
So which is it? Are they universal, or will you be producing two versions?
Old 11-24-20, 10:53 AM
What I am trying to say is the heater is universal for both versions. The heater will have two sets of holes (.070) one set is used for P models, and the other set used for un-pressurized.
The holes for a pressurized aircraft are .050 from the center line of the part, .600 inches apart.
The un-pressurized aircraft has the top hole .100 from the center line (yes the front hole will look like a Mae West), and the lower hole is .150 from the center line, these holes are also .600 apart.
These dimensions are from the SE1230-7 template as described in ME75-6.
Installation will be using two #50 drill bits (supplied) that you will put in your existing holes, peel off the release paper from the back of the heater and slide down over the the two #50 bits which will align the heater to the aluminum pitot block. One wire from the heater will be RTV'd down the channel on the pitot block to the Thermo Disc temp controller, the other wire will connect to the aircraft blue power wire. Once this is completed you will leave the #50 bits in place, place RTV on the heater unit and install in the strut fairing. When the unit is installed in the strut fairing with the two screws, then the #50 bits will be removed. These instructions are what is described in the maintenance manual, and ME75-6 Replacement Procedure, and Figure 1, Pitot Head Replacement 337, F337, T337G, FT337G
So the long and the short of it, instead of making two different parts, all four of the .070 holes are incorporated into one part making it a universal fit when installed, RTV will seal the extra set of holes.
Dan
Old 11-24-20, 06:19 PM
Thank you for the clarification!
Old 11-25-20, 09:47 AM
Can you post a picture when you have one? A photo always helps.
Old 11-26-20, 10:31 AM
When I have one in hand I will post a pic
Dan
Old 11-27-20, 02:03 AM
LostKiwi's Avatar
LostKiwi LostKiwi is offline
I'll definitely take one!
Happy to go the "owner produced" route.
Leighton.
Old 12-16-20, 12:40 PM
First five units arrive today, will post some pics and more info over the weekend after I evaluate them.
Dan
File Type: jpeg 843293BB-A201-4A53-BDA9-A69F57ABDB3F.jpeg (146.5 KB, 2531 views)
File Type: jpeg F1792910-E50F-4DE2-ACDF-2EF5C20E725D.jpeg (159.7 KB, 2503 views)
File Type: jpeg 2F057BDB-283C-49C9-8711-BDA0734799A9.jpeg (160.4 KB, 2475 views)
Old 12-17-20, 10:31 AM
Dan,
That is exactly what I need. Let me know how to order it.
Tripp
Old 12-22-20, 04:11 PM
For those that would like to go the owner produced parts please PM me with your email and I will provide you with the specifics for ordering.
I have ran the heater for 3.5 hours continuously last week in the hangar without any problems. I will have 3 units that should be able to ship by the end of the month. The unit in the circuit with the thermostat pulls 2.3 amps.
The kit will include, heater unit, Cessna style single wire connectors and pins for the power wire and the ground wire, push on connectors to connect to the thermo disk, two #50 drill bits for alignment and installation, tube of high temp RTV, 4 ty-raps, and installation instructions. A requirement will be that the installation be checked with an external power supply to verify that the thermostat (thermo disk) is working properly. And a word of caution, Do not power the heater until the installation is complete in the strut fairing.
Dan
937-603-2459
File Type: jpeg FF376067-049A-41F9-9361-81E59CED741C.jpeg (233.7 KB, 2469 views)
