Unread 07-13-20, 08:58 AM
Thanks Jim,
Interesting to see your W&B from Cessna from 1969. Mine is about 5 pages, and it is similar in the sense - but it also includes the whole equipment list for all 1966 aircraft, then and 'X' or 'O' depending on if it was installed.
I was worried about the same on my my aircraft - for the last 30 years the W&B had been amended, but I was concerned about the actual weight and CofG. My reweigh went well, and right about where I thought it would be. I removed a lot of old stuff, but added a bit with a lot of soundproofing/insulation in the cabin. Nose scale was 390 lbs, LH main 1249 lbs and RH main 1243 lbs = 2882 lbs. I weighed with fuel empty, but oil full.
Cof G is 140.2 inches.
