Unread 07-11-20, 08:59 AM
Switched to C&D
I was getting a little nervous flying behind a 40 year old fuel-air bomb in continuous ignition.
Also, it was getting harder and harder to find someone who could do the pressure decay test.
Put in a separate heater hourmeter, to extend the inspection intervals and usable life.
Otherwise they assume 1/2 your flight time is with heater.
Years back I switched to the C&D heater. Lower maintenance, etc.
The install proved to be a bit tricky, and the heater output seems a bit less.
But no more pressure decay tests.
