  #23
Old 04-23-20, 07:39 AM
Quick Drain Plug
this is the one I have, You need to probe attachment as well, there is a 180 degree and a 90 degree version. This is the link to the part. I use the 180 degree version and a section of radiator hose to just have the oil go directly into drain pan. Now if I could only fin a way to keep the case clean when the oil filter comes off.
https://bogertaviation.com/products/...sa4024nm-valve
Frank
