Old 01-10-20, 05:07 PM
Hydraulic Power Cart
If any one is interested, I put together a hydraulic power cart last week for my 337A - and it worked like a charm! I was originally going to buy an adapter from Aviation Enterprises so I could use a drill, but decided on this solution instead. Pump was purchased from Northern Tool, and the various other items from them and other web-based providers. Used old hoses removed from aircraft.
Make easy work out of doing the gear swings and enables you to watch the pressure at which everything should be happening inside your powerpack. Hook it in right at the firewall as it basically simulates the pump.
If anyone is interested - I can make a better drawing of it (or pictures) and can share if you request.
Old 01-11-20, 04:51 PM
Very nice!
Old 01-12-20, 10:27 AM
Hyd power cart
Very cool. Drawing and pump part numbers would be cool
Old 01-19-20, 06:54 PM
+1 on the request for drawing and part numbers!
Thanks!
N337K-FT337GP
KLOU
Old 01-20-20, 12:08 PM
SteveG's Avatar
SteveG SteveG is offline
Had to laugh when I saw this post. I think we even used the same utility cart. Here's my take on solving the same problem, built 15 or 20 years ago.
Old 01-20-20, 08:49 PM
cessnadriver's Avatar
Smile Hydraulic Power Cart
FYI. REF: Steve G. commit about the home made mule, I used his a few times to do the gear swings. The only problem, which I'd like to know about the other members mule, is at the high pressure at the end of the gear cycle the electric motor would bog down and trip the circuit breaker. Steve uses, I think, half horse. Did the other member use a bigger electric motor??
BILLS
Old 01-21-20, 10:05 AM
SteveG's Avatar
I used a 2HP, 120V motor. It's more than sufficient to operate the gear thru its cycle but has trouble building sufficient pressure to return the gear handle to the neutral position. I suppose a 5HP, 240V motor such as might be found on an air compressor would be a better choice. More grunt, less current draw but significantly higher cost. Or design a geared drive rather than direct drive, but again at higher cost and complexity. I can't help with the weak 15amp circuit breaker.
Old 01-22-20, 09:14 AM
Drawing and parts list
For those that requested, I will put together a readable drawing with parts list soon.
Old 01-27-20, 03:37 PM
MelsML55 MelsML55 is offline
MelsML55 is on a distinguished road
UM......yeah.......I'll take that list please.
Keith 817-991-4318
Old 02-01-20, 01:18 PM
Maybe simpler
Some years back
an A&P removed hydraulic pump from the engine, leaving hoses connected.
Then used hand held battery drill to spin it.
Worked like a charm
Old 02-01-20, 07:16 PM
hharney hharney is online now
Originally Posted by n86121 View Post
Some years back
Worked like a charm
It's a good system, still being used today by a few of us out there. No risk of contamination or air in the system when using a mule. Here's a quick video of the operation, most you have probably seen it but it's worth posting again.
https://youtu.be/w67UYBa48Lg
Old 02-13-20, 01:54 PM
As promised
All who asked, here is a schematic and parts list for the hydraulic unit/cart I built for my C337A. You can PM me if you have any questions.
Old 02-13-20, 08:02 PM
Thank you Jeff!
N337K-FT337GP
KLOU
Old 02-15-20, 09:02 PM
when using a drill to power an aircraft hydraulic pump, what type of adapter is used to connect the two?
Old 02-15-20, 11:49 PM
It's a female attachment that matches the hydraulic pump. Available from Griswold Aviation in Marshall Michigan
