Unread 08-14-19, 11:26 AM
Dennis - when you said "Then another thing which was strange that I could not pull the throttle back, it was like it was stuck in same position" - was the throttle physically stuck, or just that it was not responding when you pulled the throttle back?
If there is moisture in the cable at altitude there can be situations where the frozen moisture can restrict movement
