Unread 09-06-17, 05:20 PM
Herb - in your first post, you indicate at the end of the post, after cycling the gear, it came up normally. Does that mean that the gear doors closed on that last cycle, or in ALL cases, the doors never closed? Just trying to understand if this was intermittent, or a hard failure. Do the doors close when the gear is down and locked?
Yes the doors did close some of the time. It was intermittent. They always closed with the gear extended.
