Unread 01-03-16, 07:07 PM
DrDave DrDave is offline
Thanks Herb:
I've been cleaning things up behind the panel. It looked like someone dumped a box of wire behind the panel when I started. I'm getting it all cleaned up. I'm working toward a G500 install with a few of the add-on boxes. It needs to be clean behind the panel to make a nice install. I pretty much have the co-pilot side under control. Next stop is replacing the dimmers with Max Dim units from Max Pulse/Max Dim. It is helpful to see the layout of other peoples panels.
ID:	1623   Click image for larger version
