Unread 08-13-15, 08:43 PM
JamesC JamesC is offline
If the switches are OK then consider thoroughly cleaning up the banana plug type connector in the wiring just before switch. If it is corroded/coated with oxidation then the resistance can be high enough that the gear horn can sound.
