Unread 10-01-02, 03:50 PM
GMAs GMAs is offline
George M. Amthor, Jr.
Question 3 point, 4 point.....
I think you will find that the later ones, 3 point, are just as good as the 4 point seatbelt harness... as the major reason they don't use them in the private planes is 1. they are expensive, 2. they are unconfortable, 3. they jam on impact... yep they are not as good and even thought he military and aerobatic guy and gals use them... if they ever crash... they have a heck of a time getting out of them... not to mention that you have a 3 part back and a broken neck... but, they did stop you and hold you into the seat... however the seat broke free and the weight of all the other stuff behind it... contrib to you looking like you got squeezed out of a cookie frosting decrator... as you were stopping all the goods by your seatbelts holding all...
The three point was decided to be the best and the safest...as well as the cheepest (best for the buck) because it keeps you from going forward... on impact while not jamming you in... as you can release the bottom lap belt and still get out of it without much consern for the sholder belt restrictions...
so they are cheeper, work as well and are more comfortable than the 4 points... and they can be added to your later year by attaching it to the side rail bulkhead... see later models parts manuals for details... Cessna also has a kit for upgrading your early model to the 3 point also...
Hope this helps.. G.M.>GMAs
