Unread 03-03-14, 09:44 AM
Jim Smith Jim Smith is offline
Jim Smith is on a distinguished road
Hi Ben. I'm sorry you're having a similar problem but good to know I'm not the only one, especially on the same model and year. The problem typically seems to be worse when the battery is at peak charge or the electrical system has a minimal load. To temporarily cure the problem I will take the alternators off-line and drain the battery some and then turn them back on. I use a post it note that says 'alts' that I stick right in front of me to insure I don't forget to turn them back on! I spoke with the original owner of the plane who owned it for over 40 years and said this was never a problem for him. It makes me wonder if the pilot who delivered the plane to me might have pushed the 'alternator restart' button. I've heard pushing this button when not necessary can cause odd electrical system issues. I think it somehow affects the diodes in the alternators. I've also seen other posts where someone had similar issues and found each one of the alternators had one bad diode. This could explain how the current alternates from 28-30V as it passes through cycles in the alts. Also, the only time I have flickering alternator lights is occasionally when the plane at idle, and I understand this is a normal occurrence. Let me know if you find any possible solutions and I will do the same. Thanks, Jim
Jim Smith
N555MD
1969 T337D
Unread 03-06-14, 01:43 PM
Jim
You may want to check the resistance on the alternator field wires. I have seen where there is a splice or a bad connector that increases the resistance to the point that the regulator can't compute the load.
Unread 03-06-14, 01:52 PM
Thanks Herb. I have seen other comments regarding a similar problem and it related to resistance on the field wires. Since it's a parallel system, I'm going to assume since it occurs with each alternator individually or both at the same time it must be at some point after where the field wires connect jointly. Thoughts?
Jim Smith
N555MD
1969 T337D
Unread 03-06-14, 10:16 PM
It will depend on which alternator is taking the load, assuming it is not paralleling. It could be either one or both. Start by inspecting the field wires for any suspect connections. Compare resistance on each regulator and determine if it is one. If both are the same it could also be in the control board (I think your model has this).
Unread 03-07-14, 11:39 AM
B2C2 B2C2 is offline
Hi Jim
I did an experiment yesterday where I took the battery off the charger for two days then started up the plane. All of the symptoms went away, indicating that in my case it is an effect of a fully charged battery being close to the regulator output voltage. This is consistent with it not showing up with my old beat up battery. I don't think this is much to worry about as it doesn't exceed 30V by much and fixes itself after a few minutes of running even for a fresh off the charger battery. I should mention that in addition to the new regulators and rebuilt alternator, I went through the field wiring with a meter and found that under some circumstances I could see high resistance through the alternator switch when I actuated it repeatedly. so I replaced it. Also there is a jumper lead that goes across that switch to give the regulator access to both alternators. Take a look at this as mine was heavily oxidized (black) and so I replaced it with fresh crimps. Check all the crimps associated with the field wiring for good measure. Also check the connections to the lugs attached to the field terminal on the alternator. My front alternator field lead had one strand left from lots of vibration.
Ben
Unread 03-10-14, 10:49 AM
Ben that sounds like a lot of great things to check and will go through each of those items. Also my battery was pretty much shot and have replaced it but not had a chance to fly and test yet. That could very well be the source.
Jim Smith
N555MD
1969 T337D
