Unread 09-30-02, 07:05 PM
Guy Paris's Avatar
Cool IO360 G, GB engines
Pete,
Is your aircraft normally aspirated or is it a turbo? The crank AD should not ground the aircraft or is that a reg in France? I believe the var crank comes into play when the engine needs o/h and the case is split. I don't know if Riley would have any normal G series engines however it would not hurt to check. Whats the story on the existing engines? Guy.... old72driver....
