Old 11-22-13, 08:20 PM
Not many options out there Robert, find an overhauled Janitrol or go for the C&D non AD unit
Old 11-25-13, 05:43 PM
rmorris rmorris is offline
heat exchanger
Trading voicemails with mechanic sounds like he might be able to make a heat exchange option similar to what is in his normally aspirate skymaster and remove the janitrol heater, which was an option from factory, by doing a 337 form.
Other than the obvious. make sure my CO2 detectors in the cabin are working before each flight. Any other thoughts on the subject?
What about its ability to heat at high altitudes, versus the Janirol? Anyone have the heat exchange (non-Janitrol style) heater and fly in the upper teens or even low 20s?
Old 11-25-13, 11:12 PM
Robert
Check out this thread, http://www.337skymaster.com/messages...light=janitrol
There is an attachment that details the exhaust for the T model. It indicates a muff over the muffler but only one and I don't see any scat tube connections.
You could try to duplicate a normal aspirated system on your T model but it will require a field approval for the STC as I don't think there is an STC out there. I could be wrong so you might want to give Don Neiser a call or Owen Bell as they may know.
Good luck
