Thread Tools Rating: Thread Rating: 159 votes, 5.00 average. Display Modes
Unread 07-19-13, 07:17 PM
captbilly captbilly is offline
captbilly is on a distinguished road
Turbines burn a huge amount of fuel.
The best diesel fuel engines are turbines. However, a turbo prop Skymaster is so cost prohibitive. Avgas engines are here to stay...until the unelected EPA outlaws 100LL.
Turbines have serious issues with specific fuel consumption (pounds per hp per hour). A typical small aircraft turbine will burn anywhere from 0.6 - 0.8 lbs per HP per hour, a TSIO-360 perhaps 0.5, but a diesel will burn as low as 0.3-0.35 lbs/HP per hour. That means your fuel burn at the same speed will be just about double using a turbine rather than a diesel. Even if the diesel were to weigh 500 lbs, while the turbine was at 300, you could go just as far at typical loads, and max range for the diesel would be double that of a turbine.
In addition, the specific fuel consumption of a turbine gets worse as you pull back the power. So putting in 2 750HP PT-6s would give outrageously poor fuel efficiency. Part of the reason that turbine aircraft need to fly so high to get reasonable range is that at high altitudes the engines can run at near 100% power without hitting very high IAS/CAS, which would cause a huge drag penalty. Diesels can have very high specific fuel consumption over a very large range of power settings, gasoline engines are good at lower power setting but very bad at maximum power.
I would love a diesel in my Skymaster, or Cessna 414A or anything else with a prop. The ability to use Jet-A or diesel fuel, simpler engine (no ignition system, or even a 2 stroke with no reliability issues), best possible specific fuel consumption, no icing, liquid cooling (though it could be air cooled), would all be great.
