Old 03-13-13, 04:41 PM
Jacks for T337G
I need suggestions as to the best jacks to purchase that secure our Skymaster well for landing gear cycle work.
Would be interested in used jacks if anyone should have a pair.
Jim Bennon
304.482.7161
Old 03-13-13, 09:15 PM
http://www.aircraftspruce.com/pages/...lphaJacks4.php
These are probably the most common. If you can find some used you might save a buck or two.
Remember you still need to support the booms. In the SM it only calls for one support but I like both booms supported evenly. These don't have to be hydraulic but it sure make them nice if they are.
I just converted a set of high wing jacks to boom supports. This is really a nice touch but for just using them once a year probably overkill.
The photos show a set of stands that Jerry DeSantis owns, they work well but require some blocks under and lots of lifting as the aircraft raises. The photo of the hydraulic stands are the set I converted from a set of homemade jacks for a Cardinal. The last photo is something I witnessed and it was scary. The single boom stand didn't extend very far so the aircraft was perched at about a 20 degree angle and no jack under the nose. It worked but not in my shop.
Name:	Jack Stand Jerry.jpg
ID:	1460   Click image for larger version
Name:	Jacks gear swing.jpg
ID:	1461   Click image for larger version
Name:	Jack Stand Hyd 1.jpg
ID:	1462   Click image for larger version
Name:	Jack Stand single.jpg
Old 03-14-13, 07:26 PM
Herb, thank you for the good information and pictures. I am going to order the jacks that you show Jerry using. Hopefully we can get together as our overhaul nears completion. If nothing else we can try to meet at the Coldwater fly-in.
Jim Bennon
Old 03-21-13, 10:41 AM
Tail jacks
Harbor Freight co has what are called UNDERHOIST. These sell for about 69 dollars each and can very easily be adapted to be used as tail boom jacks.
Cheers!
Jerry
Old 03-22-13, 08:39 PM
Thanks Jerry, this should take care of our jack issues.
JB
