Unread 01-15-13, 05:46 PM
Gord Tessier's Avatar
Hi sorry about that but at least it happened at annual. Count your blessings. This appears to be an electrical problem. If the pump ain't a pumpin the nothing is going to move. When you cycle the gear see if there is any current to the electromechanical pump. If there is and no joy then the pump itself may need overhaul. When was it done last? If it was a long time ago then that could be your culprit. Also check for continuity at all the microswitches in the gear door assembly. If no current to the pump check the breaker that you would have pulled to put the gear down manually. See if the current passes through it ok. Sounds like a challenge. Let me know what happens. I will monitor this thread a little more.
Gord
C-FTES
337 C-337G
Gord
C-FTES
