Old 10-15-12, 12:00 PM
Garmin 430 & 530 users
If you decide to use the SID and/or STAR feature with your panel certified Garmin GPS make sure you select the correct procedure based on your aircraft type. I don't think there are any specific to our Skymaster's but there are those for the "Big Iron" that we dream about.
Check out the attached document if you haven't seen it
Cheers
File Type: pdf Service Alert SA 1228 SIDs and STARS.pdf (113.7 KB, 2526 views)
