blinking alt lights
Guys thanks for the replies. Mark your explanation sounds very plausable and a good place to start! And Dave I'll give Gordon a call as well. When we get this figured out I'll post the results. Jim
After reading the service manual I've decided to replace the alternator field fuses as they could be the culprit. Center of the forward firewall #214 fuses. They look good but I've seen that before and still bad...old and could be the cause,,,I'll let you know if that fixes it.
Brent |
Had simular problem
In our case it was a very small short to ground in the balancing wire that runs between the alternators. Small problem that cost lots to trouble shoot due to its intermittence.
Sandy Loutitt N81C |
I don't know if the alternator field fuses were the culprit or the 6 year old alternator restart batteries, but the problem is now fixed with 10 hours and not a flash.
Problem solved
Well, I'm happy to report the installation of two Zeftronics regulators solved my flashing alternator lights problem. I still have a 1+- variation (less than the previous 3 volts or more) in voltage as the alternators cycle but that's probably due to some resistance in the alternator switches or circuit breakers.
