Old 11-03-10, 07:43 PM
FMild's Avatar
FMild FMild is offline
FMild is on a distinguished road
Interesting discussion. I've flown two larger aircraft with gear limiting speeds; one does not differentiate (165 KIAS period), the other which specifies retraction, extension, and extended speeds, all different. Not knowing which is why I posted that.
The rear doors certainly must be a reason for the speed, but I'm curious if the small panel that stays extended from the nose gear could be a culprit as well.
