Old 07-19-09, 05:14 PM
Hank Hank is offline
Hank is an unknown quantity at this point
Thanks. I have visually checked the main gear uplocks and all appears fine, the nose gear uplock is under an inspection panel that only be opened when the plane is on jacks. Can the switches be tested when the plane is on the ground or does the plane need to be on jacks? And to add to the confusion sometimes the gear works normally on the first try.
